Simplicity 5581 - It's a Sew-Along!
Re: Simplicity 5581 - It's a Sew-Along!
Postby lendube on Mon Jul 23, 2012 10:30 am
Turned out great! I should have put the vents in too but didn't. It is a nice finishing touch.
Postby sewingmom on Mon Jul 23, 2012 11:45 am
Your daughter is growing up. THe blouse is perfect for her and looks great, even the collar that you say is wonky.
Postby temom on Mon Jul 23, 2012 12:16 pm
Thanks. I changed the picture so you can see it better. The collar wonkiness can only be seen in the inside of the shirt. She really likes it, with the only complaint is that if she leans on something, the button shafts bother her. I was thinking of putting that coverall type stuff that Marty uses for embroideries on it, so it will cover the button thread and just be a bit softer.
Postby bridesmom on Mon Jul 23, 2012 4:01 pm
So very cute!! And she is just adorable too.
Postby MartySews2 on Mon Jul 23, 2012 5:30 pm
Cuteness factor aside, it looks great on your daughter who is very pretty. Good job, Theresa!!!
Postby temom on Wed Jul 25, 2012 12:55 pm
Thanks everyone.
Marty, the coverall stuff that you use for your embroideries - is it sew in or iron on? I can't remember, but I did buy some, I just need to dig it out. I do know that the last time I looked at it there were no instructions with it. :?
Postby MartySews2 on Wed Jul 25, 2012 3:09 pm
Theresa, the stabilizer that I use most on my embroideries is Floriani's Heat & Sta Tear-Away that I buy from my dealer. That is what I used on the preemie gown. I use different types of stabilizers depending on the project. For this one of the denim pockets, I used a medium weight tear-away. It's about $30 a roll for 25yds. You won't find it at any Hancock or Jo-Ann's stores. It is different from garment interfacing which I don't buy locally either, I digress. I just hoop the stabilizer, spray some 505 spray on the denim, press by hand to the stabilizer, & stitch. Afterwards, I pull away the excess. I can usually get 2 design hoopings from one piece of stabilizer for my 4 x 4 hoop. The excess I save for my small hoop of 1-1/2 x 2 inch hoop. That's good for minature designs. Hope that this helps.
