need help with pattern view A#2069 simplicity
Re: need help with pattern view A#2069 simplicity
New postby DorothyL on Sun Oct 21, 2012 2:55 pm
There are a lot of things I have learned different ways of doing from what the pattern companies suggest and usually use my own way (well it's usually Nancy or Sandra or someone whose name I forgot's way).
New postby MartySews2 on Sun Oct 21, 2012 3:36 pm
Normally, I scan directions to see if there is something very different than normal construction. Otherwise, I construct in segments ... ie: blouse front, front placket, darts, etc & then the back. Next I'll construct the collar & collar band, add cuffs to the sleeves, etc. Last of all, I'll put all of the parts together starting with shoulder seams. I usually put sleeves in using the flat method with side seams & the hem being the last thing that I do. Buttonholes are done before I add the sleeves & side seams. It's just easier for me. Basically, the bias tape around the collar on your pattern, SM, will be less bulky than sewing a seam when there wasn't supposed to be one. Costumes are not couture sewing. I'm sure that you will do just fine.
