Updates to SWU
Important info from Kaitlinnegan, your SWU administrator.
Re: Updates to SWU
New postby Pudge99 on Wed Feb 27, 2008 11:44 pm
Kaitlin,
It appears that the link to the SWN archives is not working.
Re: Updates to SWU
New postby boblinnegan on Thu Feb 28, 2008 12:59 am
Pudge99 wrote:It appears that the link to the SWN archives is not working.
Sorry Gina, I was moving it to a different location just then. It should either be working now, or will be shortly. You shouldn't be up so late. :-)
Bob
boblinnegan
Re: Updates to SWU
New postby temom on Thu Feb 28, 2008 5:49 am
It works this morning, using IE. Who knows? Thanks!
Re: Updates to SWU
New postby jwright on Thu Feb 28, 2008 7:30 am
kaitlinnegan wrote:Jen - see this thread: View New Posts
Here is the explanation I gave in that thread:
Edited to add: Ok, the definitive answer is that "View new posts" shows the new posts since you last logged in. So, if you have it set to log you in automatically, it never gets reset and shows a bunch of old posts toward the bottom of the list. If you get logged out at some point, the "new posts" get reset and would happen to be all unread. Hopefully that makes sense -- anyway, the feature has not changed. As before, if you want to look for new unread posts, you can just look from the top down for unread posts as they are sorted by date.
So, you probably got logged out and your "new posts" got reset and now only shows the posts since you last logged in. If you click "View active threads" instead you can see the last 75 posts from newest to oldest, not just the new ones since you logged in last. Hope this helps! :)
Please pardon my stupidity. I think I may have been asleep when I wrote that. :)
jwright
Re: Updates to SWU
New postby Pudge99 on Thu Feb 28, 2008 7:30 am
Bob
I figured you were probably doing updates, but figured better let them know just in case. It worked just fine this morning.
Re: Updates to SWU
New postby Magot on Thu Feb 28, 2008 12:03 pm
Thanks BobandKaitlin - I use Safari and it is fine with that too.
Re: Updates to SWU
New postby kaitlinnegan on Sun Mar 02, 2008 3:43 pm
Update on the View New Posts feature -- with the software update it did actually change. Now clicking "View New Posts" only shows the new posts since you last visited the site (not since you last logged in). As I said before, if you want to view more than that, click "View Active Threads" to see the 75 most recent threads.
Re: Updates to SWU
New postby fabric_addict on Sun Mar 02, 2008 6:19 pm
Thanks. I think that'll be a nice feature.
fabric_addict
Return to Announcements
