Season 10, Episode 7
Discuss Project Runway, the TV show about sewing, fashion, and design.
Postby kaitlinnegan on Fri Aug 31, 2012 6:44 pm
The Onion's AV Club has funny reviews of each episode this season, this week's episode here: http://www.avclub.com/articles/oh-my-lo ... lor,84122/
I suppose everyone is freaking out a bit at this point. Making even the simplest of garments seems to be too much--extreme sleep deprivation seems to be catching up with them.
I finally realized where I recognized Christopher's signature textile from--I think someone has posted it here before, but I can't seem to find it now. I believe you would sew through several layers of flannel, then cut through all but the bottom layer for kind of a rag quilt.
Re: Season 10, Episode 7
Postby LeapFrog Libby on Sat Sep 01, 2012 10:29 am
I believe that technique is called Chennielle (sp). I have seen it called that on different sewing programs. There is even a notion for it. Like a cutter but the bottom blade is stationary and only the top cuts. To use , you slide the bottom blade over the very bottom layer in between that and the rest of the layers and cut. After washing the layers fluff up like a rag quilt.
Postby sewingmom on Sat Sep 01, 2012 11:43 am
That sounds like something fun to play with.
Postby kaitlinnegan on Sat Sep 01, 2012 3:22 pm
LeapFrog Libby wrote:I believe that technique is called Chennielle (sp). I have seen it called that on different sewing programs. There is even a notion for it. Like a cutter but the bottom blade is stationary and only the top cuts. To use , you slide the bottom blade over the very bottom layer in between that and the rest of the layers and cut. After washing the layers fluff up like a rag quilt.
Yes! Chenille is it exactly--thank you! I love how they are all worked up over it, like no one has ever done it before. It always looks a bit imprecise and raggedy to me when Christopher does it.
Postby missfleecy on Sat Sep 01, 2012 6:40 pm
Good find, Libby!
It looks to me like all of his creations are fraying so much that they would soon fall apart....
~ Miss Fleecy :doh:
missfleecy
Postby ninifav on Sun Oct 14, 2012 1:22 pm
Down to the last runway...Will be interesting...
Paula
ninifav
Return to Project Runway
