Scallop Place Napkins
Curtains, pillows, and more!
New postby Brenisback on Tue Oct 02, 2007 9:41 am
I made a table cloth in gold... I want to make the napkins with a scallop edge...how do you know where to start...I mean to make sure there is a scallop on each cornner :doh:
Brenda
People come into your life ...for a Reason a Season or a Lifetime.
Brenisback
Re: Scallop Place Napkins
New postby LeapFrog Libby on Tue Oct 02, 2007 9:48 am
Bren, I always do this on paper with a pencil , so I can erase.. Use whatever gives you the shape and experiment.. If you put the scallop right in the center of each corner, then one side should do the trick for the pattern.. That is, if you are working with a square of fabric.. Do the corners first , then measure what space is left and come up with what will fit in there.. draw it in then see if they match the corner ones.. if not, then adjust to fit.. after you get it right on paper, then go to your fabric. Don't forget to add seam allowances..
New postby Brenisback on Tue Oct 02, 2007 9:56 am
:applause: Thanks Libby ...your so wonderful...I think I will be able to do this ...if I have a problem I will be picking your brain again .
Brenda
Brenisback
New postby DorothyL on Tue Oct 02, 2007 10:01 am
Well, I just wrote a big long thing saying basically what Libby said.
Draw it on paper first then use that as a template.
When you decide how big you want the napkin, measure from corner to corner and divide by how big you want the scallops to see how many go between the corners -- remember there is half a scallop on each side of the corner.
Or you could divide by how many scallops you want to see how big they should be.
Yeah, that's what Libby said. So I'll shut up.
I'm not so good at these math things anyway.
New postby LeapFrog Libby on Tue Oct 02, 2007 10:23 am
Dorothy,
My Dad always told me " Great minds run together"... LOL
New postby Sancin on Thu Aug 25, 2011 4:19 am
Brenisback - good to see you back here! I hope all is well with you.
New postby Magot on Thu Aug 25, 2011 4:31 am
Yay Bren, Good to see you!
New postby Mom of Six on Thu Aug 25, 2011 5:25 am
Sancin wrote:Brenisback - good to see you back here! I hope all is well with you.
her post was from 2007
New postby Magot on Thu Aug 25, 2011 5:53 am
duh
New postby kaitlinnegan on Thu Aug 25, 2011 7:37 am
Sorry guys, this thread was bumped by a spammer.
Return to Home Decor
