Knitting a v neck question
New postby bridesmom on Sat Sep 15, 2012 9:38 am
I have taken a round neck pullover sweater and made a v neck but now I am not sure how to make a neckband, the pattern has you pick up so many stitches and knit a 5 row ribbing and cast off but that won't work if I have a V. Any ideas??
Re: Knitting a v neck question
New postby lendube on Sat Sep 15, 2012 11:04 am
How about picking up however many stitches you need and making an overlapping band of about an inch?
New postby J H on Sat Sep 15, 2012 2:05 pm
Pick up the stitches as for a round neck - mark the stitch that is at the centre of the V. With right side facing you, that is always a 'knit' stitch. On every row decrease one stitch at either side of that central stitch. Continue every row in the same manner until the rib is big enough :) Always keep the rib patternn going while decreasing ( I always knit two together through the back of the stitch before the central one and in the front of the stitch after the central one - this is on the row with right side facing you)
Does that make sence to you? Or have I totally confused matters :?
Jill
When not dressed in 17th century clothes..... I play with motorhomes........ and other things
J H
New postby bridesmom on Sun Sep 16, 2012 6:17 pm
I think that makes sense, I will try it tonight
Return to Other Crafts
