Does this sound familiar to anyone? I can get a photo next time it happens if that helps at all.
Edit: I should mention I have threaded and rethreaded everything and the tension is correct
Little Bear wrote:Piney, no I tend to just pull the fabric out when I've reached the end as long as the needle isn't still in the fabric? I'm assuming this is wrong then?
Stop with the needle as usual (just out of the fabric) and gently remove the fabric. What does it look like? Now lower the presser foot and take a few stitches and with the needle up high (you might need to adjust/turn the wheel by hand) gently remove the fabric. Any difference?
pinecone wrote:what we really need is to slow down a bit
