Funnel neck knit top
New postby kaitlinnegan on Thu Oct 25, 2007 4:17 pm
Without further ado, I present Vogue 7799:
A very quick and easy top to make. I only ran into trouble sewing in the sleeves - probably because I had never done it before, plus I had wanted to sew the sleeves in flat but forgot until after I had already sewed up the side seams. :doh: So, I sewed them in round (?), which was a bit tricky. I used my serger for all the construction except the hems, for which I used a twin needle on my sewing machine. It's a bit on the loose side, even though I am between sizes according to my measurements and made the smaller size. It is wearable, but I think for the next one I might try some adjustments - either making the next size down altogether or narrowing the shoulders and tummy area on this size. I will definitely be making this one again -- possibly another one of this view, and I'll definitely be making view C (the crossover style).
This is the first top from my SWAP wardrobe. I had intended to wear it under a jumper or jacket, but I think the collar might be a bit too "stand out" for layering. We'll see. I will definitely get a lot of wear out of it on its own. Thanks for looking - comments, questions or suggestions are very welcome as usual! :D
Re: Funnel neck knit top
New postby MartySews2 on Thu Oct 25, 2007 6:47 pm
Lovely top Kaitlyn. You are certainly doing very good work for only starting to sew in the past few years. I like the collar and the shirt looks comfy. :)
New postby bridesmom on Thu Oct 25, 2007 7:41 pm
Great job Kaitlin. I agree with you, I'd take the shoulders down one size as it looks fine across the bustline.
New postby Glennssister on Thu Oct 25, 2007 9:36 pm
You look good in it. great job!!!!!!!!! :applause:
Glennssister
New postby DorothyL on Fri Oct 26, 2007 2:50 am
It does look great. I like that you jump in and try anything.
New postby LeapFrog Libby on Fri Oct 26, 2007 4:02 pm
Looks Great ! ! Proud of you, girlfriend ! !
New postby temom on Fri Oct 26, 2007 5:02 pm
Looks great! You inspire me, that is for sure!
New postby Sunshine on Sat Oct 27, 2007 3:55 am
Good job. My sewing looked nothing like this when I first started. The first few pieces I made only got worn around the house once. I can imagine what you'll be making in a year or so. :applause:
Sunshine
New postby AndreaSews on Sat Oct 27, 2007 6:02 pm
Holy smokes, Kaitlynn! If you turn sideways, you'll disappear! I know it's off topic, but it is striking what you have done for yourself. <pat on back>
And the turtle neck is nice too :)
Andrea
AndreaSews
New postby trini on Sat Oct 27, 2007 8:27 pm
A really great job; you have done well.
Trini.
trini
