How to use clear elastic to stop gaping neckline
Re: How to use clear elastic to stop gaping neckline
New postby bridesmom on Mon Jan 02, 2012 8:35 pm
Ok, now that you are done, here's what I do. I have done this on a number of rtw tshirts that stretch out in the neck or ones I sew and screw up and get a gaping neckline. I open up the back seam of the neck ribbing (or whatever is there) on the inside of the shirt. I then put a safety pin through one end of the clear elastic and feed it through the neck piece (like you would with a drawstring). Then I make sure that I have enough in to hold the neck in place and not have it too gathered, (or have it how I want it) and with both ends of the clear elastic on the outside, crossing over each other, I resew the neck band seam stitching in the ditch across the seam, then a few hand stitches closes the seam if need be and it's done. It works great on a thin neck band or ribbing, that is about the same width or a bit wider than the clear elastic.
If you sew the elastic on the outside, it helps to have a teflon foot to help it glide over the elastic, and I also have laid tissue paper over it to also help the foot go, but it makes it hard to see the elastic so it's a slow process as you have to keep checking. I really like the teflon foot.
And one last edit, I never serge fleece, cause I always end up with a mess. And the edges really don't need the serger finish, cause they don't run or fray. But that's just me.
New postby temom on Mon Jan 02, 2012 8:37 pm
Well here it is with the rest of the ensemble. I'm not at all happy with the neckline, but she absolutely loves it, so I will to.
The shirt itself is bunched up because of what she had been doing. It does lay flat. The neckline - no way does it lay flat!
Silky Fleece PJ ensemble.jpg (26.83 KB) Viewed 4514 times
New postby bridesmom on Mon Jan 02, 2012 8:38 pm
She does look thrilled, and that's what counts mom!
New postby MartySews2 on Mon Jan 02, 2012 9:52 pm
Theresa, that's cute. Love it & your daughter is happy so that's is what only counts.
New postby DorothyL on Tue Jan 03, 2012 6:47 am
There is no thread on the bobbin!
Well, that was a spew coffee all over the computer moment.
She look warm and happy. I just love that smile.
New postby sewingmom on Tue Jan 03, 2012 12:53 pm
She looks great in that wonderful outfit. Great for sleepovers and lounging around the house.
New postby lendube on Tue Jan 03, 2012 8:32 pm
What a happy face!! She'll be warm and cozy for a long time to come.
New postby bridesmom on Wed Jan 04, 2012 12:30 am
And just for you Theresa :applause: :applause: :applause: :applause: :applause: :applause: :applause: for admitting to the first stupid mistake of the New Year! I missed that earlier, glad Dorothy brought it up again though I'm betting you're wishing she hadn't :lol: :lol:
New postby DorothyL on Wed Jan 04, 2012 7:27 am
My computer is still sticky
Dorothy.
New postby temom on Wed Jan 04, 2012 1:29 pm
bridesmom wrote:Ok, now that you are done, here's what I do. I have done this on a number of rtw tshirts that stretch out in the neck or ones I sew and screw up and get a gaping neckline. I open up the back seam of the neck ribbing (or whatever is there) on the inside of the shirt. I then put a safety pin through one end of the clear elastic and feed it through the neck piece (like you would with a drawstring). Then I make sure that I have enough in to hold the neck in place and not have it too gathered, (or have it how I want it) and with both ends of the clear elastic on the outside, crossing over each other, I resew the neck band seam stitching in the ditch across the seam, then a few hand stitches closes the seam if need be and it's done. It works great on a thin neck band or ribbing, that is about the same width or a bit wider than the clear elastic.
Laura, that is a great technique. I will try that with my next one.
And I am more than happy to admit to the first screw up of the year, and I have a mental image of Dorothy spewing her coffee on the computer screen. And now she has a visual reminder of me, every time she looks at her sticky screen. :D
