by paroper on Thu Aug 23, 2007 7:04 am
Always use directional sewing on satin. There are fabrics that may not matter as much but satin isn't one of them. Check the pattern to see which way you should sew. There should be little arrows or triangles that show the correct direction. I believe you sew up pants from the bottom, the same as skirts, but I could be wrong. If you don't use the directional sewing, the seams will be wavy.
pam
Bernina 200e, Artista V5 Designer Plus, Explorations, Magic Box, Bernina 2000DE & 335 Bernette Serger, Bernina 1530 Sewing Machine, Bernina 1300 DC Overlock (with coverstitch)
