This is what i want to make
New postby temom on Fri May 10, 2013 3:24 pm
This is the type of strip quilt I want to make. It calls for 37 strips of colored strips, and 37 strips of neutral strips. I have 48 colored strips, which leaves me with almost enough for the binding. I will either use some of the neutral strips into the binding, or supplement it with something else.
Anyway, I am going to put this together as a quilt as you go.
http://www.allpeoplequilt.com/images/im ... pslg_1.jpg
Re: This is what i want to make
New postby Magot on Sat May 11, 2013 1:28 pm
Using a jelly roll?
New postby pinecone on Sat May 11, 2013 2:47 pm
Cute quilt but IMHO, quilt as you go might be a challenge with 21/2" strips if you are doing it where a strip goes in the middle over the batting and backing, join to another right sides tog, then flip and sew another in the same method.....
New postby Skye on Sat May 11, 2013 5:17 pm
Nice quilt - I have a quilting friend who has made several baby quilts using strips and quilt as you go. Nice quick easy projects providing ypour batting isn't too lofty.
New postby temom on Sun May 12, 2013 3:24 pm
Piney, I think you might be right. I may sew 2 strips together, so I will be working with a 4 inch strip.
Everything is delayed, as I found that the sheet I bought for the backing is a cotton/poly blend, and I need it to be 100% cotton. I guess I will run to the fabric store.
Here is a jelly roll: https://encrypted-tbn3.gstatic.com/imag ... cLgvvgZpWQ
And a quilt from a jelly roll race: https://encrypted-tbn0.gstatic.com/imag ... ol8J96Yvpg
( I just googled and picked an image)
