Twirl Skirt Tutorial
New postby Sews4kate on Thu Aug 16, 2007 8:43 am
When I first started posting on SWN I was asked how I made the twirly skirts for my dd. So I had written some directions and Mary posted them in her articles. I am posting them here so they don't get lost. I am the author, so I don't think I need permission, right?? :D
I will add pictures of the process to it later, I've got some pics of the process, but I'm going to make a new one soon and hope to get better shots:D A few more pics of the ones I've made in the past are at the end.
*I've written these directions for anyone to use, You can use the finished product any way you'd like. The written directions are not copyrighted, however, if you are going to copy it to another site, please link back to here or give me credit! I've seen these exact directions posted elsewhere with the person taking credit for them :evil: :evil: :evil: *
*Measure your child’s waist. Example 20"
*Decide how long you'd like the skirt to be: ie: 15"
*Decide how many tiers you would like: 3
*Divide your length by the tiers and add seam allowances:
15 divided by 3 = 5.
Example:
If using 5/8 seam allowance, add seam allowances of 5/8" remembering that the top piece you will need to add enough to allow for a casing for the elastic size you choose + the 5/8", so 5+ 5/8 + 1"= 6 and 5/8". On the middle piece it will be 5/8" on both top and bottom so you add 1 1/4". On the bottom, allow for whatever hem you like to do, I like to add 5/8" and do a narrow hem, so I've added 1 1/4.
*You will be cutting and/or piecing fabric into strips that are 1 1/2-2 times the width of the strip above it.
Example:
Waist size 20", top tier is 30-40" wide
Middle tier is 45-80"
Bottom tier is 67-120"
I usually round up my numbers depending on the fabric. You can add seam allowance to this too.
*I usually make the skirt starting at the bottom/longest strip. It seems to be easier than starting at the top. Sew the strip ends together right sides tog. Mark the quarter marks to help ensure even gathering. Gather the top edge (I zig zag over dental floss to make the gathers). Then sew to the next strip right sides together, press, trim, and finish the edge. You can top stitch if you want. Repeat with each strip adding it to the top of the previous one.
*Make a casing at the top/waist for your elastic by finishing the raw edge and folding over and stitching, or press the raw edge under and edgestitch leaving an opening to insert your elastic.
*Cut elastic to fit comfortably around waist, insert into casing and close the opening. Adjust fullness on the elastic.
If you want to add this skirt to a t-shirt then don't make the casing and don't allow extra for the elastic, just the regular seam allowance. Just attach it to the t-shirt as you did each strip right sides together using a ballpoint needle.
Hope that is what you were looking for! If you have any questions I'd be happy to help!
Wendy
Sews4kate
Re: Twirl Skirt Tutorial
New postby kaitlinnegan on Thu Aug 16, 2007 9:10 am
Wow! Adorable! Thanks for posting the tutorial.
New postby FranW on Thu Aug 16, 2007 4:25 pm
Wendy,
These are fantastic! Thank you 8-)
Happy Sewing!
Fran
FranW
New postby temom on Thu Aug 16, 2007 7:26 pm
Fantastic - Thanks so much!
Also love your Avatar!
New postby fabric_addict on Sun Aug 19, 2007 9:37 pm
Thanks for the instructions. You inspired me to create a spreadsheet which would automatically calculate the measurements as per your instructions.
fabric_addict
New postby PaulineG on Mon Aug 20, 2007 1:22 am
What a fantastic idea fabric addict. I might do that too.
Pauline
PaulineG
New postby fabric_addict on Mon Aug 20, 2007 7:29 pm
I realized that I didn't understand this part as well as I should. For example, I noticed that some of your pictures have skirts with patches. How did you decide what size to make all the patches for each length that goes around the circle? Does the 1.5 to 2 inches you mention?
Say, for example I wanted a 14 inch long, 4 tier skirt for a 25 in. waist, 0.5 in seams, 1 in elastic casing, and 1 inch hem. Would I be correct to say that the skirt strips would be as follows:
TOP - 5.250 in wide and 31.0 in long (one piece) or 32.0 in long (two pieces)
MIDDLE1 - 4.750 in wide and 47.5 in long (one piece) or 50.0 in long (two pieces)
MIDDLE2 - 4.750 in wide and 72.3 in long (one piece) or 77.0 in long (two pieces)
BOTTOM - 5.250 in wide and 109.4 in long (one piece) or 117.0 in long (two pieces)
How would the measurements change if I were to not use the elastic (attach directly to the shirt) would the top strip be more like 20+seam*2+ease? Subsequent strips being 1.5 times larger.
Am I getting it?
Sews4kate wrote:
[color=#BF40BF]*Measure your child’s waist. Example 20"
Example:
Example:
fabric_addict
New postby Sews4kate on Mon Aug 20, 2007 8:58 pm
ok, let's see if I understand your questions.
one of the great things about this skirt is the measurements don't really have to exact math to still look good. When I do the patchwork type, I figure out how wide the strips need to be from top to bottom:
waist circumference x 1.5 or 2 (depending on fullness desired)
next strip is 1.5 or 2x's the measurement of the waist ~ If I want this to be patchwork I'd then figure that out. So say, the strip needs to be 40" wide/circumference. (I don't have a calculator handy, so I'm using easy numbers and still my math may not be exact LOL) I'd decide how wide I want each square or rectangle based purely on how I want it to look, divide that into 40 then add seam allowance. So maybe I want each square to be 4". I'd divide that into 40 and come up with that I need 10 squares. Add 1/2" seam allowance and you'd get that you need to cut 5" squares. (5" by however long you need it to achieve the skirt length desired)
40 (width/circumference needed) divided by 4"(desired patch width) = 10 squares/rectangles 4" + .5 seam allowance (both sides of square) = 5"
sorry, without a calculator I can't check your math (I am so not a mathematician!!) But, it appears that each one is approximately 1.5 times the previous, so that would be correct. If you want me to check the math I can do that another time (just way to comfy/lazy right now to get up to find a calculator)
if you are attaching to a shirt, measure the circumference of the shirt, make the top tier 1.5 - 2 times that measurement for width. For length, divide your number of tiers by desired length and just add regular seam allowances to the top tier and middle tiers (so if you have .5" seam allowance, you'd add an inch) for the bottom tier add 1 seam allowance and 1 hem.
Does that help?? I'm a bit sleepy so I hope I made sense!!
Just have to say, when I do these skirts, I always round the numbers to whole numbers or fudge a little to meet the amount of fabric I have on hand (or sometimes I just kinda eyeball it :oops: ) , so sometimes it is not necessarily exact. As long as you have the waist a comfortable fit and each tier below is wider by atleast 1.5 times, you'll get a pretty good result. Also, if you want more "twirl", make sure you do atleast 2x's the circumference. In the pictures I posted, they are at least 2x's. The only one that was figured at 1.5x's is the Tshirt dress, as you can see there isn't as much fullness. You can also make the tiers different measurements, in one of the skirts, there was only 3 tiers with the middle one longer than the rest. So you can really do whatever you want kwim? So don't worry too much about the math :D
Here are some pictures of the strips I cut on one of the skirts
Please post back if you need more clarification!
Wendy
Sews4kate
New postby fabric_addict on Tue Aug 21, 2007 9:16 pm
Thanks so much! Yes, you definitely cleared it up for me. Also that extra picture you included was helpful too.
No need to check the math. I think I've worked the bugs out of my spreadsheet. I guess I'm one of those people who have a tough time just eyeballing and sewing. Thanks again! I'm excited about trying to make one of these skirts now.
fabric_addict
New postby mozeyrn on Fri Aug 24, 2007 9:44 pm
Thanks Wendy for the extra details! I already had your email printed out for the twirl skirt but luckily someone asked about the alternating patch skirt because I was getting ready to ask. I've got my three fabrics for the tiers but I don't think they're going to be long enough - :shock: I can't go fabric shopping because my dh will have my head if I don't start using up some of the fabric I have.
He still is hating FL (he's depressed & angry & blames me) and wants to go back to NJ tomorrow if he could so I'm trying not to rock the boat - buying more fabric would definitely rock the boat!
- Maureen.
Learning something new with every stitch!!
Kenmore 16231, White 2900 & Brother PE-750D
mozeyrn
